Return of speed after fault.
FIXEDTopic Options
- Return of speed after fault.
24-10-2017 3:57 PM
Hi.
Last week my connection dropped several times. I found there was a terrible crackle on the line causing the disconnections which has since been fixed last Thursday. My speed now sits at about 45mb on BT speedtest but used to be about 55-60.
Could anyone tell me how long it could be until the profile begins to rise?
Thanks for your time.
Fixed! Go to the fix.
Message 1 of 3
(558 Views)
2 REPLIES 2
Re: Return of speed after fault.
24-10-2017 4:16 PM
Message 2 of 3
(549 Views)
24-10-2017 4:45 PM
Thanks. I'll give it another week and see how it stands then.
Message 3 of 3
(533 Views)
