Return of my Broadband fault.
Yet again my speeds are way down. Just tested & I'm getting 15/5 & the Btw tester is showing a fault. Could one of the excellent PN forum staff please have a look & try & sort out this intermittent fault?.
Many thanks,
Nick
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Return of my Broadband fault.
Hi Nick,
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 50.8 37.1 11.3 7.4 34.3 Available -- -- Yes --
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 44.9 Mbps
Upstream Speed 12.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 777.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-60M Downstream, Interleaving Low - 0.128M-12M Upstream, Error Protection Off
Time Stamp 2017-06-14T16:15:00
Testing the line isn't showing any problems and the sync is within the estimates.
Are the slowdowns at specific times of the day and are you on a wireless or wired connection?
 Chris Parr
 Plusnet Staff
Thanks for your detailed response. The slowdown occurs spasmodically & it shows initially on my wireless laptop but is confirmed when I chabge to wired & is confirmed by the Btw tester.
Today I'm back to normal, showing 41/12 at my end so obviously all is OK for now. Intermittent faults are not unknown locally as the lines are overhead with some very dodgy connections.
I guess we can close this case for now 7 keep fingers crossed. Thanks again for the promptnresponse.
Nick
Fixes: 173
Glad to hear it's back to normal at the moment, please do let us know if the problems return though.
 Harry Beesley
