Restricting my childrens internet access times.
biggun1
Hi!
I'm finding it difficult to tear my little darlings away from their tablets after school when it's home work time. On my old router there was the option to restrict cetain devices access times. Is this an option on the Technicolor tg582n as supplied by PlusNet?
Thanks in advance
Fixes: 136
Re: Restricting my childrens internet access times.
What firmware is your router using?
If you log in by going here http://192.168.1.254 entering admin as the username and the routers serial number that starts with CP (All in Capitals) it'll be next to software release.
If it's starts with 8.4.4 we'll need to get your router upgraded to the latest one.
 Matthew Wheeler
biggun1
Hi Matthew! Yes it starts 8.4.4  Undecided
Fixes: 136
I'll ask a colleague if we can get it upgraded for you.
[EDIT]
We can't at the moment but if you go here you can upgrade it manually
http://products.plus-payh.co.uk/firmware/
You'll have to use a Windows 7 or XP machine to do it.
 Matthew Wheeler
biggun1
OK, I'll do that. But which one do I update to?
Fixes: 136
10.2.5.2.FO should be the one you need.
 Matthew Wheeler
biggun1
Thanks, I'll do it first thing tomorrow morning and report back.
biggun1
Hi!
Installed the update as sugested (Had to run it in compatibility mode for Windows Vista SP2 for some reason??) and now I have the ability to control wireless access times from the interface.
Thanks for your advice!
