Restricting my childrens internet access times.
- Re: Restricting my childrens internet access times...
07-10-2015 3:08 PM
Hi!
I'm finding it difficult to tear my little darlings away from their tablets after school when it's home work time. On my old router there was the option to restrict cetain devices access times. Is this an option on the Technicolor tg582n as supplied by PlusNet?
Thanks in advance
Thanks in advance
Message 1 of 8
(1,099 Views)
7 REPLIES 7
07-10-2015 4:29 PM
What firmware is your router using?
If you log in by going here http://192.168.1.254 entering admin as the username and the routers serial number that starts with CP (All in Capitals) it'll be next to software release.
If it's starts with 8.4.4 we'll need to get your router upgraded to the latest one.
Message 2 of 8
(856 Views)
07-10-2015 5:12 PM
Hi Matthew! Yes it starts 8.4.4
Message 3 of 8
(856 Views)
07-10-2015 5:12 PM
I'll ask a colleague if we can get it upgraded for you.
[EDIT]
We can't at the moment but if you go here you can upgrade it manually
http://products.plus-payh.co.uk/firmware/
You'll have to use a Windows 7 or XP machine to do it.
[EDIT]
Message 4 of 8
(856 Views)
07-10-2015 5:25 PM
OK, I'll do that. But which one do I update to?
Message 5 of 8
(856 Views)
07-10-2015 5:27 PM
Message 6 of 8
(856 Views)
07-10-2015 5:30 PM
Thanks, I'll do it first thing tomorrow morning and report back.
Message 7 of 8
(856 Views)
09-10-2015 10:15 AM
Hi!
Installed the update as sugested (Had to run it in compatibility mode for Windows Vista SP2 for some reason??) and now I have the ability to control wireless access times from the interface.
Thanks for your advice!
Message 8 of 8
(856 Views)
