Reset SNR/Profile due to power cuts
Can someone please reset my profile, I have lost quite a bit off my speed due to some problems with constant power cuts a while ago. Usually i can sync at 9-10 mpbs but now i am lucky to get 8mpbs.
Thanks in advance.
Fixes: 287
Re: Reset SNR/Profile due to power cuts
We can't reset fibre lines I'm afraid. This can only be done by an engineer whilst out on the job. They'd need to call their support team DCoE [Diagnostics Centre of Excellence].
Having said that, your sync speed isn't banded. It's just in sync at a slow speed, which is unfortunately within the expectations of your line [7.1mbps and 11.4mbps]
Sync Status In Sync
Downstream Speed 7.4 Mbps
Upstream Speed 1.1 Mbps
Profile Name 0.128M-10M Downstream, Retransmission High - 0.128M-2M Upstream, Error Protection Off
I'd recommend running through the checks here just to rule out any internal wiring issues. If things don't improve, it's possible that your speed may recover by itself.
