Requires Login/authorisation
- Re: Requires Login/authorisation
20-04-2020 8:42 PM
My router looks OK, blue light on. My phone says I am connected but the login/authorisation is required. This takes me to the following message:
SERVICE INFORMATION
You have been connected to this page due to one of the following reasons. You must now shut down your internet browser and internet applications before attempting to reconnect. This may clear the issue immediately, if not then please select the appropriate action from list below.
Your service provider is currently unable to accept your connection request, please wait and reattempt later or contact your service provider for more information.
Or
You have attempted to access an invalid Service Provider domain, check your user details.
Or
You are testing your connection using bt_test_user@startup_domain. Please proceed to next step as advised by your Service Provider
Or
You are testing your connection to your service provider using bt_test_user@domain. where "domain" is your Service Provider domain name. Please proceed to next step as advised by your Service Provider.
Or
The access circuit to your Service Provider is currently down. Your service should be resumed soon. Please try again later or contact your Service Provider
Page maintained by BTWholesale
Not a problem with my phone as ps4 and tablet cannot access Internet either.
Any advice anyone?
SERVICE INFORMATION
Or
Or
Or
Or
Any advice anyone?
Message 1 of 2
(3,500 Views)
1 REPLY 1
21-04-2020 3:13 PM
Thanks for getting in touch @Jolakeside
Can you try resetting the router using the pinhole on the back?
Message 2 of 2
(3,442 Views)
