Request for IP Profile Reset Please
gemmapowell
I'm currently connected at a stable 54Mbps but for over a year now my IP profile hasn't budged off 38.4.
Please could someone reset the profile please so I'm capable of using the speed my modem is connected at?
Thanks in advance.
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: Request for IP Profile Reset Please
Hello there and thank you for taking the time to get in touch with us via our community forums. I'm sorry to hear that your speed profile dropped. If you private message me your username I will be happy to look into that tomorrow for you.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
gemmapowell
Thanks for the fast response! thats very kind of you, I'll PM you now
Plusnet Staff
Plusnet Staff
Fixes: 115
@gemmapowell Thanks for your patience. I've updated your speed profile now, if you either reboot your router or disconnect/reconnect your PPP session you should be getting the correct throughput. Apologies for that.
 Plusnet Support
gemmapowell
Hi @Anoush.
Thanks for that, I can see it's been updated in the plusnet dashboard but it's still stuck at 38.4 on btwholesale speedtest.
As you can see from the screenshot I'm connected above that so not sure why that isn't rising?
Thank you
Fixes: 136
If the IP profile on the BTWholesale speedtest is low you'll need to raise a fault here
 Matthew Wheeler
gemmapowell
Ive gone down that road a few times (as you can see if you look at the account under my username gemmapowell). It never gets resolved - hence being stuck on 38.4 since i've signed up. I just thought id have one last try before I look for alternatives now my contract is up.
Thanks anyway
Plusnet Staff
Plusnet Staff
Fixes: 115
I'll test your broadband and will get back to you by the evening. Sorry that it's still not resolved.
[Edit]
I missed Matthew's post, if your IP profile is low I would also recommend raising a fault to us as we would possibly need to arrange an engineer appointment.
 Plusnet Support
Plusnet Staff
Plusnet Staff
Fixes: 159
Just to add to Anoush and Matthew's post, on Fibre unfortunately we cannot reset profiles or make remote alterations, this is only done after an engineer has fixed an issue.
 Chris Parr
 Plusnet Staff
gemmapowell
An engineer has been sent out in the past, twice I believe, 1st one found no problems so seemed pretty annoyed to be sent out. The second one I wasn't even expecting and told him I just requested an IP Profile Reset, he also seemed annoyed and said there's nothing to do if there isn't any problems and got back in his van.
I understand you guys can't reset the IP Profile, that's fair enough. But all this time I've been paying for the 80 down package to be limited below the 40 down package threshold, when you can see from the screenshot I'm connected at a higher rate.
Thanks for your help in the matter, just a shame you guys don't have the ability to fix problems like this.
