Request GEA
- Re: Request GEA
Request GEA
29-01-2019 1:20 PM
Hi PN
Could I have GEA Test result please
Re: Request GEA
29-01-2019 3:45 PM
Re: Request GEA
29-01-2019 4:07 PM - edited 29-01-2019 4:27 PM
Thanks. I have to kept an eyes on my line because since this morning something is so strange getting more errored seconds on downstream rather than upstream. Nothing has changed for modem, line etc. The downstream SNR has playing up since this morning was all over the place varies from 4.6dB to 6.2dB
Max: Upstream rate = 24585 Kbps, Downstream rate = 77305 Kbps Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 80000 Kbps
Since Link time = 8 hours 2 min 53 sec FEC: 41898125 59050 CRC: 768 18 ES: 96 6 SES: 13 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0
Re: Request GEA
29-01-2019 7:45 PM
Hi @goldenfibre,
Checking the SNR margin for your downstream, I can see that it has decreased over the last 24 hours and this is likely the reason you have seen an increase in errors. As the connection has been stable for 25 days, DLM may have started to reduce the SNR in an effort to increase performance but this would be unusual with the sync rate being 79.9Mbps.
Let us know if the circuit starts to perform poorly or drops out intermittently.
Thank you.
Re: Request GEA
30-01-2019 8:42 AM - edited 30-01-2019 8:44 AM
Hi PN
24 hours are 324 errored seconds and 39 serverly errored seconds on downstream. So far no DLM act. But, I do think my FTTC cabinet are now target SNR 3dB in place? I am not sure.
Stats recorded 30 Jan 2019 08:37:52 DSLAM type / SW version: BDCM:0xa48c (164.140) / v0xa48c Modem/router firmware: AnnexA version - A2pv6F039g1.d24m DSL mode: VDSL2 Profile 17a Status: Showtime Uptime: 25 day 14 hour 34 min 42 sec Resyncs: 0 (since 29 Jan 2019 08:00:29) Downstream Upstream Line attenuation (dB): 11.6 0.0 Signal attenuation (dB): Not available on VDSL2 Max speed (kbps): 77278 23026 Connection speed (kbps): 80000 19999 SNR margin (dB): 4.9 11.8 Power (dBm): 12.5 0.1 Interleave depth: 8 1 INP: 49.00 0 G.INP: Enabled Not enabled Vectoring status: 5 (VECT_UNCONFIGURED)
Re: Request GEA
30-01-2019 11:37 AM
Re: Request GEA
30-01-2019 11:41 AM - edited 30-01-2019 11:43 AM
@adamwalker I was told No need to worry about DLM intervention with those error rates - you'd need to be up at 60-120 ES/hour (depending on your ISP) to be in the red. Is that correct?
Re: Request GEA
30-01-2019 12:57 PM
Hi @goldenfibre
Honestly, I have no idea. We do not have access to the level of detail in terms of our suppliers DLM software that would be required to prove/disprove that statement.
Perhaps other members of the community or your original source might be able to shed some more light on this for you?
Best wishes
Dave
Re: Request GEA
30-01-2019 7:38 PM
Oh dear, it looks like the next time their modem re-syncs, @goldenfibre might end up with less than the full 80Mb. If not having the full 80Mb is intolerable, I'd recommend cancelling the service entirely. Or just live with less than the full 80Mb.
Re: Request GEA
30-01-2019 8:24 PM
Re: Request GEA
31-01-2019 8:22 AM - edited 31-01-2019 8:23 AM
PN
The errored seconds on both downstream and upstream are now ZERO overnight. SNR are now above 5dB and below 6dB. Still at 80/20. No DLM so far.
Re: Request GEA
31-01-2019 4:44 PM - edited 31-01-2019 4:47 PM
ejs ?
your quite rude to be honest why with the stupid comments?
i thought we are here to help each other
Re: Request GEA
31-01-2019 8:00 PM
If it ain't broke, don't fix it.
Re: Request GEA
11-02-2019 11:38 AM
Could I have GEA Test request please.
Re: Request GEA
11-02-2019 2:19 PM - edited 11-02-2019 2:20 PM
Sure thing, here you go:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 79.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 257.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed on Week Days |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | From 00:00 to 17:30 |
Interference Location | Customer Premise |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-01-29T14:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 80.0 Mbps | 80.0 Mbps | 80.0 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 899.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-11T13:54:50Z | 2019-02-11T14:09:50Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
