Replacing Technicolor Router
- Replacing Technicolor Router
12-02-2016 3:11 PM
Going to replace my fibre modem & Techniclor router, but don't know what to get. Wifi signal is very weak possibly due to the amount of devices connected these days.
Should I get this Hub One or is there a better alternative, ideally around the £100 mark.
Thanks in advance
Thanks in advance
Message 1 of 5
(1,088 Views)
4 REPLIES 4
Re: Replacing Technicolor Router
12-02-2016 3:18 PM
For that you have a reasonable choice
I suggest starting here http://forum.kitz.co.uk/index.php/topic,14436.0.html
I would suggest - as a minimum - dual band and at least two (preferably three) external aerials
Message 2 of 5
(802 Views)
12-02-2016 3:24 PM
Thank you very much Oldjim, I will have a read.
Message 3 of 5
(802 Views)
12-02-2016 4:21 PM
Did you ever get the firmware upgrade for the 582n If it was a plusnet one with the dant-t board they were still pushing firmware for this. Long after you were told they couldnt.
One of the things it was meant to improve was the wifi. .
Message 4 of 5
(802 Views)
12-02-2016 4:32 PM
The router is stock, not done anything to it.
Will see if I can locate this firmware upgrade
Message 5 of 5
(802 Views)
