Repeated disconnections
edocaster
Hello,
I have been a Plusnet customer for coming up to 3 years now. Generally, service has been good. However, in the last week I have experienced frequent disconnects - many times a day.
I am on 40/10 FTTC using a Plusnet Hub One. Here is an excerpt from a log around the time of a disconnect:
20:49:55, 09 Apr. (28558.970000) PPPoE is up -​ Down Rate=38171Kbps, Up Rate=9542Kbps; SNR Margin Down=8.2dB, Up=9.2dB
20:49:55, 09 Apr. (28558.960000) CHAP authentication successful
20:49:55, 09 Apr. (28558.910000) CHAP Receive Challenge
20:49:55, 09 Apr. (28558.910000) Starting CHAP authentication with peer
20:49:55, 09 Apr. (28558.910000) PPP LCP Receive Configuration ACK
20:49:55, 09 Apr. (28558.900000) PPP LCP Send Configuration Request
20:49:55, 09 Apr. (28558.900000) PPP LCP Receive Configuration Reject
20:49:55, 09 Apr. (28558.900000) PPP LCP Send Configuration ACK
20:49:55, 09 Apr. (28558.890000) PPP LCP Receive Configuration Request
20:49:55, 09 Apr. (28558.890000) PPP LCP Send Configuration Request
20:49:06, 09 Apr. (28509.370000) PTM over DSL is up
20:49:02, 09 Apr. (28505.720000) CWMP: session closed due to error: Could not resolve host
20:49:02, 09 Apr. (28505.690000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:49:02, 09 Apr. (28505.690000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:48:32, 09 Apr. (28475.280000) CWMP: session closed due to error: Could not resolve host
20:48:32, 09 Apr. (28475.240000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:48:32, 09 Apr. (28475.230000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:48:31, 09 Apr. (28474.810000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
20:48:29, 09 Apr. (28472.930000) PTM over DSL is down after 12 minutes uptime
20:48:29, 09 Apr. (28472.920000) PPPoE is down after 11 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
20:48:27, 09 Apr. (28470.210000) PPP LCP Send Termination Request [User request]
20:47:55, 09 Apr. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:44374-​>[151.101.61.16]:443 on ppp3)
20:47:53, 09 Apr. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:35492-​>[99.86.105.209]:443 on ppp3)
Does that offer any clues as to why these disconnects may be happening? Is there anything else I should be looking at?
Any assistance to make my line stable, as it once was, would be greatly appreciated.
Thanks.
2 REPLIES 2
Davejplatt
Re: Repeated disconnections
Openreach have probably swapped your line with another customer who complained and given you their bad line. It's the standard way they fix line faults.
stevewx
Login to your router.
Troubleshooting
Event Log
Boot
Do you have anything like this?  "Boot reason: watchdog reset (cause: 0x3)"
I've had >100 of this particular failure since August 2020.
0x3 does seem to be a known problem with the Home Hub One and the similar BT HH5.  I've actually just logged on to search for it.
Regards,
Steve
