Removed Pro addon the other day, now p2p is slow
- Re: Removed Pro addon the other day, now p2p is sl...
27-10-2014 9:20 PM
Quick edit - To clarify i'll download 700mb or maybe 1g or so then turn utorrent off completely, I don't leave it open hogging bandwidth and normally it would peak around 4MB / sec within 30 seconds of torrent starting. Currently sitting at 469kB/s
Re: Removed Pro addon the other day, now p2p is slow
27-10-2014 9:29 PM
Re-activated pro and speeds increased dramatically.
I suppose this is why you don't interfere with things when they're working fine..
27-10-2014 10:06 PM
27-10-2014 10:13 PM
Are you limiting your upstream bandwidth in your client? Whilst it's harder to do on fibre, if you max out your upstream your downstream will suffer.
27-10-2014 11:12 PM
Removed the pro addon a couple of days ago and when I tried downloading via uTorrent before was at, 400 / sec and literally as soon as I re-activated it in member centre (by literally I mean 5 seconds) the speed increased dramatically.
28-10-2014 8:47 AM
29-10-2014 2:03 AM
29-10-2014 2:26 AM
It is apparently off on my ipv6 test account tho and aside from slow psn downloads its performance is ok. Regarding psn speeds, when I route via one of my socks proxies its close to line speed, direct via plusnet its about 1/12th of line speed.
29-10-2014 10:00 AM
29-10-2014 10:11 AM
I suggest you raise this as a fault.
29-10-2014 10:21 AM
29-10-2014 11:09 AM
