Remove DHCP pool
- Re: Remove DHCP pool
Remove DHCP pool
12-12-2014 11:26 AM
How do I remove a dhcp pool from 8CM0, do I need to disable the dhcp server then remove the pool then re-enable ?
Can't remember, the command would be handy if you good people could remind me
pool name LAN_guest
pool name LAN_guest
Message 1 of 4
(2,286 Views)
3 REPLIES 3
12-12-2014 11:58 AM
I think there's some information on how to disable DHCP on npr.me.uk - it might be as a subsection of another command though.
*edit* Found it, http://npr.me.uk/together.html - there's some steps in here for disabling DHCP does this help?
Message 2 of 4
(521 Views)
12-12-2014 1:13 PM
This may help:
http://www.o2help.co.uk/change-lan-ip/
Message 3 of 4
(521 Views)
12-12-2014 5:29 PM
Thanks for your replys, I just unticked the use dhcp server option without restarting the router, then deleted the guest pool and re-enabled the dhcp server again without restarting the router. I guess at some point the router will need a restart.
Message 4 of 4
(521 Views)
