Remote Desktop not working
- Re: Remote Desktop not working
04-01-2021 9:16 AM
Trying to connect to my work RDP and getting the below blocks
09:01:33, 04 Jan. | BLOCKED 3 more packets (because of ICMP replay) |
09:01:32, 04 Jan. | OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 150.143.122.39->184.50.113.59 on ppp3) |
09:00:57, 04 Jan. | OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 150.143.122.39->104.85.57.12 on ppp3) |
09:00:54, 04 Jan. | BLOCKED 2 more packets (because of ICMP replay) |
09:00:54, 04 Jan. | OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 150.143.122.39->104.85.57.12 on ppp3) |
08:47:48, 04 Jan. | IN: BLOCK [16] Remote administration (TCP [209.141.59.208]:44068->[150.143.122.39]:22 on ppp3) |
08:46:35, 04 Jan. | ( 673.090000) Firewall level changed from 'Disabled' to 'Default' via GUI |
08:46:27, 04 Jan. | ( 664.470000) Port forwarding rule deleted via GUI. Service: Secure Web Server (HTTPS), protocol: TCP, external ports: any->443, internal ports: 443, internal client: Home-PC |
08:46:22, 04 Jan. | BLOCKED 2 more packets (because of ICMP replay) |
08:46:20, 04 Jan. | OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 150.143.122.39->3.215.97.17 on ppp3) |
08:42:57, 04 Jan. | ( 454.690000) Port forwarding rule added via GUI. Service: Secure Web Server (HTTPS), protocol: TCP, external ports: any->443, internal ports: 443, internal client: Home-PC |
08:40:09, 04 Jan. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.70]:49739->[34.248.40.183]:443 on ppp3) |
08:40:05, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [192.168.1.80]:64460->[178.249.97.70]:443 on ppp3) |
08:39:59, 04 Jan. | IN: BLOCK [15] Default policy (TCP [45.129.33.153]:48307->[150.143.122.39]:17253 on ppp3) |
08:39:52, 04 Jan. | IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [66.102.1.188]:5228->[150.143.122.39]:59030 on ppp3) |
08:39:51, 04 Jan. | IN: BLOCK [15] Default policy (TCP [45.129.33.153]:48307->[150.143.122.39]:19254 on ppp3) |
08:39:47, 04 Jan. | IN: BLOCK [15] Default policy (TCP [209.197.3.15]:443->[150.143.122.39]:64488 on ppp3) |
08:39:46, 04 Jan. | IN: BLOCK [15] Default policy (TCP [95.101.143.33]:443->[150.143.122.39]:64473 on ppp3) |
08:39:35, 04 Jan. | IN: BLOCK [15] Default policy (UDP [62.210.172.8]:5080->[150.143.122.39]:5070 on ppp3) |
08:39:35, 04 Jan. | IN: BLOCK [15] Default policy (TCP [45.129.33.41]:53582->[150.143.122.39]:41389 on ppp3) |
08:39:33, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.72]:44736->[18.202.31.69]:443 on ppp3) |
08:39:26, 04 Jan. | OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.80]:64460->[178.249.97.70]:443 on ppp3) |
08:39:26, 04 Jan. | IN: BLOCK [15] Default policy (TCP [46.48.53.186]:63927->[150.143.122.39]:445 on ppp3) |
08:39:24, 04 Jan. | IN: BLOCK [15] Default policy (TCP [78.128.113.42]:57148->[150.143.122.39]:5581 on ppp3) |
08:39:23, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.73]:37227->[3.249.8.95]:443 on ppp3) |
08:39:21, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.71]:57816->[34.244.83.138]:443 on ppp3) |
08:39:19, 04 Jan. | IN: BLOCK [15] Default policy (TCP [192.35.168.232]:32502->[150.143.122.39]:9263 on ppp3) |
08:39:16, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.74]:38915->[34.247.50.44]:443 on ppp3) |
08:39:14, 04 Jan. | IN: BLOCK [15] Default policy (TCP [94.102.51.28]:50839->[150.143.122.39]:8153 on ppp3) |
08:39:12, 04 Jan. | IN: BLOCK [15] Default policy (TCP [89.248.165.45]:49535->[150.143.122.39]:4493 on ppp3) |
08:39:12, 04 Jan. | BLOCKED 6 more packets (because of Default policy) |
08:39:10, 04 Jan. | IN: BLOCK [15] Default policy (TCP [212.159.3.154]:443->[150.143.122.39]:64454 on ppp3) |
08:39:04, 04 Jan. | IN: BLOCK [15] Default policy (TCP [34.196.82.147]:443->[150.143.122.39]:64447 on ppp3) |
08:38:56, 04 Jan. | BLOCKED 1 more packets (because of Default policy) |
08:38:54, 04 Jan. | IN: BLOCK [15] Default policy (TCP [94.23.155.54]:443->[150.143.122.39]:64490 on ppp3) |
08:38:47, 04 Jan. | BLOCKED 1 more packets (because of Default policy) |
08:38:46, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.70]:49739->[34.248.40.183]:443 on ppp3) |
08:38:45, 04 Jan. | IN: BLOCK [15] Default policy (TCP [72.246.97.90]:443->[150.143.122.39]:64330 on ppp3) |
08:38:34, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.72]:44736->[18.202.31.69]:443 on ppp3) |
08:38:26, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.73]:37227->[3.249.8.95]:443 on ppp3) |
08:38:21, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.71]:57816->[34.244.83.138]:443 on ppp3) |
08:38:19, 04 Jan. | IN: BLOCK [15] Default policy (TCP [199.117.180.44]:443->[150.143.122.39]:47409 on ppp3) |
08:38:06, 04 Jan. | IN: BLOCK [15] Default policy (TCP [192.241.214.222]:44293->[150.143.122.39]:5094 on ppp3) |
08:38:05, 04 Jan. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.74]:38915->[34.247.50.44]:443 on ppp3) |
08:38:05, 04 Jan. | BLOCKED 1 more packets (because of Packet invalid in connection) |
08:38:04, 04 Jan. | OUT: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [192.168.1.70]:49739->[34.248.40.183]:443 on ppp3) |
08:38:03, 04 Jan. | BLOCKED 2 more packets (because of Default policy) |
08:38:01, 04 Jan. | IN: BLOCK [15] Default policy (TCP [52.212.193.208]:443->[150.143.122.39]:64422 on ppp3) |
08:38:01, 04 Jan. | IN: BLOCK [15] Default policy (TCP [185.175.93.104]:50545->[150.143.122.39]:3394 on ppp3) |
08:37:58, 04 Jan. | IN: BLOCK [9] Packet invalid in connection (Packet not in tcp window: TCP [1.1.1.1]:443->[150.143.122.39]:51165 on ppp3) |
Message 1 of 3
(227 Views)
2 REPLIES 2
17-01-2021 1:49 AM
How do you connect to the remote RDP? What URL are you connecting to?
*Usually* RDP only works on a local network, but it *IS* possible to either put a Server using RDP publicly on the internet (not suggested, it is HIGHLY insecure!), or you can use an "RDP Gateway" at the remote site.... this needs a secure connection & login, and your connection is then forwarded to the relevant server.
Give us a bit more info, and we'll try to help
Message 2 of 3
(160 Views)
17-01-2021 12:45 PM
It's a URL but when I connect and check the log the ip show blocked? When I use it vanish it works
Message 3 of 3
(137 Views)
