Remote Administration
geffers
Folks,
I look after my daughter's 40/2 fibre connection which previously suffered numerous disconnects when uploading.
@bobpullen applied a fix to my router and it is definitely more stable but suffered a disconnect a short while ago after 11 days - not bad but checking the log there are a number of entries similar to shown below showing 'Remote Admin'.
17:35:22, 02 Mar.	IN: BLOCK [16] Remote administration (TCP [186.57.29.186]:3963-​>[146.90.11.242]:22 on ppp3)
17:34:59, 02 Mar.	IN: BLOCK [16] Remote administration (TCP [177.87.212.188]:53150-​>[146.90.11.242]:22 on ppp3)
17:20:41, 02 Mar.	IN: BLOCK [16] Remote administration (UDP [185.94.111.1]:37494-​>[146.90.11.242]:161 on ppp3)
I am the only one who accesses the router and I didn't at the times shown.
What might these refer to?
Geffers
2 REPLIES 2
30FTTC06
Fixes: 4
Re: Remote Administration
Block meaning Blocked!
geffers
Yep, apologies, just realised it is the firewall blocking.
I've had so many problems of late (maybe resolved) with uploads that I mistakenly thought it had something to do with a disconnect at the same period.
Geffers
