Reduced Sync Speed - Frequent Disconnects
- Reduced Sync Speed - Frequent Disconnects
01-11-2016 9:24 AM
Hello, I have been suffering the last couple of weeks with reduced sync speed, from 40mb down / 6.5 up to 30 down and 3 down now.
I have contacted support and they have advised me to hook up to the test socket for 3 days to rule that out.
I was wondering can someone confirm how frequently I am disconnecting and when the issues started. The last 24 hours I have started to notice the drop outs, before that I didn't.
At the time of writing this, my router says the connection is up for 4.5 hours, and sync'd for 3 days 8 hours.
If someone from plusnet can confirm whether my issue is loss of sync, or if its plusnet network migration process which is disconnecting me, that would be great
Re: Reduced Sync Speed - Frequent Disconnects
01-11-2016 12:45 PM - edited 01-11-2016 12:45 PM
01-11-2016 12:56 PM
Wow that is strange... If it was a line fault would we expect those disconnects to be more spread out and constant rather than bundled together, could the be a modem/router fault?
I'm suspecting this more so, as the router claims the connections dropped, but not lost sync, where as you are claiming it actually has lost sync.
Prior to this 7 day period, was the line stable or did it exhibit similar faults?
01-11-2016 5:53 PM
Taking the cover off the master socket and using the test port seems to have resolved the issue
Line state: Connected
Connection time: 0 days, 00:26:14
Downstream: 41.57 Mbps
Upstream: 6.559 Mbps
This is the fastest my service has ever been, and this must now be being restricted by all the disconnects from DLM, so will probably increase if it stays stable.
What does it mean the fault is, and please can you provide some more stats to confirm the disconnects have now stopped.
Kind Regards
02-11-2016 10:01 AM
We haven't seen any disconnections since 5.20pm last night:
