Recurring Connection Problem
jim13
About six weeks ago I reported that I was experiencing frequent disconnections (usually lasting only a few minutes) and after various checks it was established the problem lay somewhere outwith my home. Three weeks later the fault was signed off as having been fixed.
Well, it's back. Six disconnections this morning to add to a similar number every day for the past couple of weeks. Normally it would just be a minor irritation but I have been uploading manuscripts to and down from Kindle Publishing and the breaks mean I keep having to start these from scratch.
Unfortunately Online Help is currently unavailable and  as for getting through on landline - no luck.
I think I'll go and eat worms.
jim13
Re: Recurring Connection Problem
I was a Legend last year. Now I'm a Dabbler.
Must have lost in the relegation play off.
BrightonRock
Fixes: 5
Use the online portal to report a fault at https://www.plus.net/apps/kbdfaults if Plusnet staff don't pick up your post.
jim13
Yes, I've reported it there
Many thanks
Fixes: 67
Hello there,
I can see from ticket 175087300 that it looks like the issue is resolved.
Let me know if you're still experiencing any issues though.
 Adam Walker
