Recommendation for wall mounted router, please
- Recommendation for wall mounted router, please
on 10-12-2015 1:15 PM - last edited on 06-04-2016 9:51 AM by PlusnetLiam
I have fibre plusnet via the supplied separate BT Openreach modem and Netgear router.
The phone line is in the hall, so that's where the kit is (the PC is actually situated in a room on the floor below, connecting via a TP-Link powerline).
I want to replace the separate modem and router with one unit (which also needs to supply a wireless signal, of course). I also want to wall mount the unit.
Finally, as its in the hall, I'd rather not have a shiny black box with lots of flashing lights - ideally I'd like white and unobtrusive.
Any recommendations?
Re: Recommendation for wall mounted router, please
04-04-2016 8:05 AM
04-04-2016 8:41 AM
04-04-2016 8:41 AM
07-04-2016 4:04 PM
I don't know how unobtrusive a router with three antennas (antennae?) can be, but this one - the TP-Link Archer AC1900 - is white, VDSL2-capable and should be compatible with your Powerline kit:
(There's also a cheaper, but well-reviewed, TP-Link router, the W9970, reachable from the same page. Fewer frills, but may do the job for you.)
07-04-2016 4:17 PM
I'm tempted to buy one.
NE
