Recently upgraded from broadband to fibre, but...
FIXED- Subscribe to RSS Feed
- Re: Recently upgraded from broadband to fibre, but...
13-04-2016 8:06 PM
I received an email on the 8th of April, that my product change is complete.
Today, I received the new hub, plugged in, I have internet, but the speed seems to be the same based on the various (bt, speedtest.net, etc) tests.
How long will it take to actually complete the product change?
Fixed! Go to the fix.
13-04-2016 8:12 PM
If all the work has been done it should be straight away, sounds like it hasn't. It would be worth getting in touch with support, via Chat, or calling, or they may see you post on here and check it out.
13-04-2016 9:49 PM
I got the same email early, I just confirmed it wasn't activated early and awaited the date given via text message
If you Like it, give it a
13-04-2016 10:04 PM
13-04-2016 10:06 PM
Obviously wait until Plusnet have responded but if you've got the new hub I assume you've got it fibre enabled. So that's the BTOR modem connected to your router.
Some folks - myself included have ditched the BTOR modem and gone for a single router - the Billion 8800NL seems a favourite. In my case it doubled the speed. Purchased from Amazon so if it didn't make any difference then you can get a full no-quibble refund.
Still, see what happens. Your speed may pick up or Plusnet may be able to do something.
14-04-2016 7:30 AM
I can't say that PN is on top of the game in the information management.
So I will receive a second modem? I didn't know that. (I should expect it, as years ago I was with BT fibre, and I had two modems/routers.) However PN's (and Sagem's) documentation doesn't mention it either, it only says plug it in the wall...
Alright, waiting game it is then.
14-04-2016 7:39 AM - edited 14-04-2016 7:56 AM
Hopefully staff will pick this up today and give you some idea on what's going in.
14-04-2016 12:28 PM
Thanks etdsaunders!
At that case I hope a CS staff pops in to answer.
Anyway what is the availability of the chat support function? Any time I check it, it is unavailable for me.
14-04-2016 12:38 PM
Just looking in to this now for you, will reply back shortly.
14-04-2016 12:40 PM
Looking at your account we emailed you on the 2nd with the following information:
Our supplier have advised that your broadband activation date has been changed to 15/04/2016.
This is still correct and you're due to switch tomorrow.
Do you have a pop-up blocker or similar on your browser? Try adding an exception for our site.
14-04-2016 12:47 PM
Ghostery/Adblock active of course.
Thanks for the help and solution Chris, the reminder must have slipped through the cracks. My bad.
