Recent slow fibre speeds
Gribbin
Hey.
For at least a few days (but maybe longer) my formerly 40mbps fibre has be running at 2.5-3mbps.
I've tried running several speed tests all the with the same result. And my planet account details say 'estimated lone speed 40mbps. Current line speed 2.9mbps'
I have raised a ticket but was hoping you might be able to help progress or give me an idea what the issue might be.
Many thanks.
Fixes: 152
Re: Recent slow fibre speeds
Is the modem turned off at the moment as it's showing that way when we test it?
 Matthew Wheeler
Gribbin
Hi Matthew.
Apologies yes I'm at work and turned it off this morning. Will post when I am back online.
Gribbin
Hi Matthew.
Fibre is back online.
Plusnet Staff
Plusnet Staff
You'll probably need an engineer. I'm getting this into BT systems for you now. I've put some stats on the ticket for you. In the mean time, please leave your modem on.
 Tony
 Plusnet Support
Gribbin
Thanks Tony
