Recent consistent drop in speed
- Recent consistent drop in speed
Re: Recent consistent drop in speed
19-05-2021 2:27 PM
Here. It's interesting that the maximum expected speed is 62.12 Mbps since in use I've certainly seen considerably higher figures when downloading. But even with 62.12 as a maximum, my currect 52-ish speed represents a noticeable drop.
19-05-2021 2:32 PM - edited 19-05-2021 2:36 PM
I don't have speed records saved before last month, but this, from the site I've used regularly might be of interest:
19-05-2021 2:34 PM
As @BD says above, you are getting inside the estimates for your line - to the router, which is the demarcation point for intervention by Plusnet/BT
19-05-2021 2:39 PM - edited 19-05-2021 2:42 PM
So the problem, whatever it is, lies after the router? I just found an earlier recorded speed test: in 2016 I was getting a steady and consistent 60+ Mbps.
19-05-2021 2:41 PM
Ben, thanks for your reply, which I've only just seen. I accept that the speed I'm getting is well within the expected range: as I said, everything is working perfectly, but that sudden and consistent speed drop was very noticeable and I thought it worth mentioning.
19-05-2021 2:43 PM
In a word, yes, the problem is inside your own (local) network - you will never get 100% of your profile speed due to overheads, but you are not really achieving the optimum.
19-05-2021 2:44 PM
Thanks, John. I'm not aware of anything having changed, but I'll investigate. And Ben, it is a wired connection throughout.
19-05-2021 4:39 PM - edited 19-05-2021 4:53 PM
Well, this is interesting. When I did that BT speed test I first rebooted my modem as directed; and as I said, it made no difference.
I just tried turning the modem completely off, leaving it for ten minutes or so, then powering it up again. After a few minutes to let it settle down, this was the result:
Which is not quite where it used to be, and doesn't match the official Plusnet up-to-the-modem figure of 64.2Mbps as reported by Ben, but does represent a considerable change. I wonder though where the reduction is happening, given a direct wire connection from the modem to a wall box and thence to my PC. Could it be the length of the cable from the modem to the wall socket? But that hasn't changed at all. Perhaps a certain dropping off is to be expected.
Many thanks to everyone for thoughts and advice.
19-05-2021 4:55 PM
Hi Bert,
Looks like your line speed dropped to around 50mbps on the 10th May at 3am and a profile our end along with it. From what I can see when the line speed recovered at 2am on the 12th, the profile on our end increased a tad later at 4am.
Since then because your connection hadn't dropped your download speed was capped at the previous line speed.
Unsure why your speed's dropped from 70mbps, that'd be a different issue but as you're within the estimated speed target for your line there's not much we can do in the way of further investigation with Openreach.
I hope this helps though.
19-05-2021 5:46 PM - edited 19-05-2021 5:59 PM
Anoush, thanks for that. I don't quite understand one thing. You say,
But if this cap was imposed on the basis of a previous line speed, presumably the 50mbps of 10th - 12th May, why is it still in place if the speed subsequently increased? Can it not be adjusted?
I noticed that something very similar has happened before. On the 13th of July 2019, following a power cut here, I reported a marked drop in speed. On that occasion, you said:
Hi Bert.
I can see your router is in sync at 67.5mbps and while there's no speed restrictions on your line, it looks like your speeds are being restricted by the profile set at an old sync rate on our system.
I've just nudged it up now, can you reboot your router and retest your speed?
After your nudge, the reported speed was 63.65mbps. If I was getting that then, why not now? And if there was no speed restriction on my line then, why is it now capped?
19-05-2021 6:02 PM - edited 19-05-2021 6:03 PM
No problem Bert, the cap wasn't in place though as it did adjust/increase at 4am on the 12th, but as your connection hadn't dropped since then, your download speed was still restricted. It's unfortunately due to the way our systems work.
It's a cliché but a reboot of the router should always be the first port of call when troubleshooting issues :)
Hi Bert.
Can't really compare this to two years ago because your sync speed isn't the same as per Ben's testing and your own router stats, your router is not in sync at 67mbps, it's sync'ing at 64mbps. You'll never get a throughput of exactly your sync speed, you'll always get a little less due to overheads of the connection.
19-05-2021 6:19 PM - edited 19-05-2021 6:20 PM
Anoush, thanks.
...your router is not in sync at 67mbps, it's sync'ing at 64mbps.
What has caused the change?
I still don't follow about capping. If there was no speed restriction imposed two years ago, why is my download speed restricted now? Has there been a fundamental change of policy?
19-05-2021 6:41 PM
@BertCoules wrote:Anoush, thanks.
That would be nigh upon impossible to say. Speeds change over time due to the way the infrastructure or wiring work. As you're within the estimated speed range for your line, Openreach wouldn't investigate further. If you want to rule out an internal wiring issue, try plugging your router into the test socket explained Here.
No change in policy at all. In fact this has been in place for as long as I've worked here (around 7 years)
There's the speed which is your router physically sync's at with the cabinet we've no control over.
There's also BT's IP profile which is typically 90 to 96% of the sync speed we likewise have no influence over.
There's also what's known as the connection profile on our own systems should always match the IP profile/sync speed and in some instances if it's lower than this then your download speed (throughput) is capped.
In this case, your router's sync speed and the profiles along with it dropped to 50mbps on the 10th May, we can't see the why. The sync speed and the profiles along with it increased on the 12th May.
However as your connection hadn't dropped when your sync speed/profiles increased, your download speed (throughput) was capped at the old rate of the 10th May, like what happened in 2019 but the difference here is that speeds are different.
19-05-2021 6:52 PM - edited 19-05-2021 6:56 PM
Anoush, thanks for the explanations.
Two years ago, my speed dropped to what I described at the time as "a consistent 52MB" - Exactly the same reduction as happened this time. Two years ago, the connection didn't drop - Exactly the same as this time. Two years ago you were able to correct it by "giving it a nudge". What is different now and what is preventing you from doing exactly the same thing again?
19-05-2021 7:07 PM
The connection profile was set too low back then. But it isn’t now because it had auto adjusted to the correct level at 4am. Your router just needed a reboot.
If you look at the sync speed on your router stats you’ll see it’s at 64mbps which is the same level as the connection profile and in turn your throughput is fine as you’ll never get exactly what your sync speed is.
