Received Fibre router
ajwilliams1310
Hi I received my new fibre router today. Do I need to wait for fibre to be activated before setting router up or can I set it now and use it for broadband until fibre is activated.
Thanks Alex
SpendLessTime
Aspiring Hero
Fixes: 53
Re: Received Fibre router
If you are currently a Plusnet ADSL customer then the new Plusnet Hub One will work now as it can handle both ADSL and Fibre.
When the swap takes place, the router will spot it and reconfigure itself for fibre.
ajwilliams1310
Ok brilliant. Thanks for the reply. I'll set it up and just sit back and wait for fibre to be activated hopefully not too long as my adsl is about 3meg on a good day.
Fixes: 9
Hi Alex, if you have ADSL broadband already with us then by all means you can plug the router in and use the new one. If not then yes you'll have to wait for the broadband order to complete before plugging the router in and getting online.
Either way if you drop me your user name I'll check what's going on with your broadband order.
Kind Regards,
Ben
 Ben Devine
ajwilliams1310
Hi Ben thanks for the quick reply. My username is [removed]
Moderator's note by Dick (Strat) Personal details moved from a public forum to a private area.
Fixes: 227
Just checking on your fibre order, I can confirm this is in progress for the 12/05/17.
You'll receive an automated email in the early hours of the morning advising the product change is complete. I'd expect the actual work to be carried out during normal business hours.
Fixes: 132
Moderator's note by Mike (Mav): I have changed the fix to @BD as per message #4.
Forum Moderator and Customer
