Really slow internet speeds
- Really slow internet speeds
26-11-2019 11:08 PM
I have been getting really poor speeds lately.
Download I normally got over 60mbps but recently only getting 20mbps if I am lucky
Upload use to be around 18mbps but now only getting 11mbps
I have logged onto my hub and played about with the channels but none of them make the slightest difference to the speed.
Can this be looked into for me please as it’s getting a PITA waiting fo programmes to buffer when I am paying for a fast fibre speed !
Andy
Re: Really slow internet speeds
27-11-2019 3:48 PM
Thanks for getting in touch @Andy74 I'm sorry to see you're experiencing speed problems. I've tested your line today and the tests are showing your router is getting a stable line speed of 76.3mbps with no issues detected.
From what I can see it appears all your devices are wireless so I suspect this may be an issue with the wireless connectivity. I'd recommend trying the steps Here to change the wireless channel as it's currently set to automatic. It may also be worth connecting some devices onto the 5GHz frequency and see how that goes.
I hope this helps.
27-11-2019 4:29 PM
I’ve had a play around with the hub Channel settings and also reset the router and things seem to be back to their normal speeds.
Cheers
Andy
27-11-2019 4:59 PM
