Really slow fibre speed
phil917k
Current BT Wholesale speed test results:
Download 0.76 Mbps   IP Profile 38.67 Mbps
Upload 2.02 Mbps Profile 10.0
 Current line speed 38.6 Mbps
Results checked via Ethernet connection but other devices getting similar over wi-fi. Seems to have been getting steadily worse over last couple of days judging by performance issues on Iplayer streaming etc.
Will be reporting a fault.
Phil
1 REPLY
Fixes: 359
Re: Really slow fibre speed
Hi Phil.
I've had a look into this for you and I can see that your circuit is on a hot virtual path. This means that the part of our suppliers network that your service is connected through, is experiencing congestion.
The good news is that there's a planned fix due tomorrow, so I've set ourselves a reminder to check back then.
Hopefully things go to plan.
