Really slow download speeds
- Re: Really slow download speeds
30-10-2016 11:54 AM
I've just started experiencing really slow download speeds. Spoke to an adviser on Saturday evening who said everything looks OK their end. Support Team have opened Question 137047523
Chat reference:4295914921 |
I've switched my PC from wifi and directly plugged it into the cable modem and the issue is still present.
The connection seems to give me approx 1.5Mb download and 8Mb upload.
https://portal.plus.net/my.html?action=data_transfer_speed returns the following
Telephone number:01793 xxxxxx
Phone exchange:TOOTHILL
Estimated line speed:55Mb (This may vary between 72.9Mb and 80Mb) - Checked on 2016-10-27 20:43:33
Current line speed:2 Mb
Can you offer any advice.
30-10-2016 12:01 PM
Next step is the BT Speedtest further diagnostics http://speedtest.btwholesale.com/
30-10-2016 12:11 PM
That gives me
Ping Lat 26.25 ms
Download speedachieved during the test was - 1.83 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-55.62 Mbps .
Additional Information:
IP Profile for your line is - 55.62 Mbps
Upload speed achieved during the test was - 4.38Mbps
30-10-2016 12:16 PM
In which case it is extremely likely that you were given a load of garbage by the rep
Try Chat and ask that the Plusnet profile is changed from 2Mb to 55.6Mb to match the BT IP profile
30-10-2016 2:40 PM
the technical support seems really lacking...
This all started when I agreed to extend my contract for an additional 18 months. I suspect something odd happened as I got an email with the following;
"Your broadband product change is now complete"
I've cancelled the 18 mth extension and will be looking elsewhere.
31-10-2016 1:53 PM
How are the speeds looking now? From what I can see everything should be back to normal .
31-10-2016 7:04 PM
Yes - everything is now back to normal.
However, I have 2 weekends a year which are free from work and children and this was one. Over the w/end I couldn't use Netflix/Amazon prime or gaming services. The plusnet support was useless as I was told there was nothing wrong with the line and then later to log a fault. I've since been told a wrong setting was applied to my account - which I mentioned was a possibility when I contacted support on Sunday (as this was indicated by another forum member).
I am assuming that this whole issue was due to the marketing people offering me a £5 discount if I sign up for an additional 18 mths - which I did the proceeding Friday before the issue started. If this is the case, the plusnet retentions marketing offer has directly led to a customer leaving. Well done.
