Really low speeds.
- Really low speeds.
Really low speeds.
16-04-2020 7:32 AM
Re: Really low speeds.
16-04-2020 11:57 AM
Hi @Crowen_2007, I've tested your line and we've found a fault on your phone line which is likely affecting this.
I've raised a support ticket on your account with what we need to do to move forward, which you can view here.
Please let us know once you've had the chance to read and respond to the ticket and we'll pick this back up for review as soon as possible.
16-04-2020 3:51 PM
16-04-2020 4:50 PM
Thanks for letting me know @Crowen_2007, it's not the telephone itself that you need to plug into the test socket but the entire broadband connection in your home should be running through the master socket, so it would just be the broadband line you connected at this time.
There's a really helpful guide on the forums here which should help.
16-04-2020 4:59 PM
16-04-2020 5:21 PM
I do apologise @Crowen_2007 the link should work here, the DSL cable from your router should be plugged into your master socket currently, either with or without a microfilter depending upon your setup.
This should then be plugged into the test socket with a microfilter, once this has been done I can complete further testing from our side as you're unable to with not having a phone.
16-04-2020 5:26 PM
