Really low download speed & High Ping
dontdisobey
So lately i have been getting extremely low download speeds (like 0.7 - 5Mbps Cry ) i used to get around 12 - 25 Mbps on wifi, i know wifi is usually unstable and wired is better, but it has been decent for nearly a year. Just wanted to know if there's something wrong with my line and if there's a fix Smiley
Excalibre68
Re: Really low download speed & High Ping
A quick fix would be to reboot your modem and router and see if that helps other than that you may need to raise a ticket but you'll probably die from old age Crazy before you get an answer lol. Crazy3
Asus Rampage V Extreme X99 , Intel i7 5960X @ 4.7Ghz , 32Gb Corsair Vengance 3200Mhz
Corsair Dual Loop Liquid Cooling , 480Gb Samsung EVO 850 HDD , WD 2Tb Hybrid HDD
EVGA 980Ti Classified , Creative Recon 3D Sound , Corsair HX1200i PSU
Logitech Z5500 5.1 Sound System , Corsair Graphite 760T Case
dontdisobey
I've rebooted my router many times, and i have heard rumours of how long it takes to get a response on a ticket and on the phones so i thought i'll just write on the forum for suggestions Grin . Thanks anyway lol Cheesy .
Martin4
Your question can't be answered without more info.
Like, what is the modem sync speed. You can get this be logging into the modem/router or here:
Also, what package are you on, fibre or ADSL?
Martin
dontdisobey
If your'e talking about the estimate speed it says: 80Mb (This may vary between 62.8Mb and 80Mb), Current line speed: 38.4 Mb. And i'm on fibre btw Smiley
rongtw
Fixes: 12
Come on PN where are you ?   3 days since OP and no reply to this ,,,, Friday evenin and its beer Oclock   PN clocked off now till monday Sad
Martin4
If your line is syncing at 38Mb/s and your only seeing 2Mb/s on your wifi, then the problem most likely lies with your wifi.
You should run a speedtest e.g. www.speedtest.net from a computer with a wired connection to your router to confirm this.
Martin
dontdisobey
Just done 2 speed tests on wired, both results were between, 25 - 28 Mbps Cheesy
dontdisobey
Welp, looks like im cancelling Plusnet and moving on to virgin media because they have a alot more reliable download speed and ping especially in my area . goodbye lol Cry
0rangecake
Don't get too excited, their network is oversubscribed too; if not more so. My friend who's with Virgin gets random ping spikes and connection issues every other evening.
dontdisobey
every other night is better than all day lol
