Really low download speed & High Ping
- Really low download speed & High Ping
14-09-2016 10:46 PM
So lately i have been getting extremely low download speeds (like 0.7 - 5Mbps ) i used to get around 12 - 25 Mbps on wifi, i know wifi is usually unstable and wired is better, but it has been decent for nearly a year. Just wanted to know if there's something wrong with my line and if there's a fix
Re: Really low download speed & High Ping
15-09-2016 12:13 AM
A quick fix would be to reboot your modem and router and see if that helps other than that you may need to raise a ticket but you'll probably die from old age before you get an answer lol.
Corsair Dual Loop Liquid Cooling , 480Gb Samsung EVO 850 HDD , WD 2Tb Hybrid HDD
EVGA 980Ti Classified , Creative Recon 3D Sound , Corsair HX1200i PSU
Logitech Z5500 5.1 Sound System , Corsair Graphite 760T Case
15-09-2016 1:44 PM
I've rebooted my router many times, and i have heard rumours of how long it takes to get a response on a ticket and on the phones so i thought i'll just write on the forum for suggestions . Thanks anyway lol .
16-09-2016 9:53 AM
Your question can't be answered without more info.
Like, what is the modem sync speed. You can get this be logging into the modem/router or here:
Also, what package are you on, fibre or ADSL?
Martin
16-09-2016 5:11 PM
If your'e talking about the estimate speed it says: 80Mb (This may vary between 62.8Mb and 80Mb), Current line speed: 38.4 Mb. And i'm on fibre btw
16-09-2016 5:59 PM
Come on PN where are you ? 3 days since OP and no reply to this ,,,, Friday evenin and its beer Oclock PN clocked off now till monday
16-09-2016 6:26 PM
If your line is syncing at 38Mb/s and your only seeing 2Mb/s on your wifi, then the problem most likely lies with your wifi.
You should run a speedtest e.g. www.speedtest.net from a computer with a wired connection to your router to confirm this.
Martin
17-09-2016 1:10 PM
Just done 2 speed tests on wired, both results were between, 25 - 28 Mbps
19-09-2016 5:09 PM
Welp, looks like im cancelling Plusnet and moving on to virgin media because they have a alot more reliable download speed and ping especially in my area . goodbye lol
19-09-2016 6:32 PM
Don't get too excited, their network is oversubscribed too; if not more so. My friend who's with Virgin gets random ping spikes and connection issues every other evening.
19-09-2016 7:27 PM
every other night is better than all day lol
