Real line speeds of 57, but Plusnet says I'm getting 78
- Re: Real line speeds of 57, but Plusnet says I'm g...
30-12-2015 9:02 AM
New customer, when I had the line installed (switching from VM) the engineer said the line quality was good and I should expect speeds in the 70s.
Started off in the mid-50s which I expected due to line training, but it's been a few weeks now and I'm still stuck there.
Oddly, today I received an email from Plusnet saying my current speed is 78 when it isn't.
Any thoughts?
Duncan
Any thoughts?
Duncan
Message 1 of 5
(731 Views)
4 REPLIES 4
Re: Real line speeds of 57, but Plusnet says I'm getting 78
30-12-2015 9:58 AM
Testing wired or wireless?
Ever helpful. Sure, I’d love to help you out. Now which way did you come in?
Message 2 of 5
(444 Views)
30-12-2015 10:27 AM
Because when Plusnet provisioned you they applied the default profile based on the 80Mb/s product and this will remain until a delta report is received and at that time it will match the BT IP profile
Message 3 of 5
(444 Views)
30-12-2015 10:44 AM
Thanks for the reply Oldjim.
I assume that means that once the delta is received the reported current line speed (including via the link in your signature) will match what I'm actually getting.
Seems strange that Plusnet's method of reporting line speed just gives a theoretical number and not the actual speed.
Duncan
Duncan
Message 4 of 5
(444 Views)
30-12-2015 10:51 AM
Agreed it is odd but that is the way it is set up and is a hang over from the time of MaxDSL when the IP profile wasn't a direct multiple of the sync speed
I wouldn't bother too much about the Plusnet number being higher it is when it is the other way round that people get twitchy
Message 5 of 5
(444 Views)
