Re: Upload speed low
Peterhaslanded
Fixes: 188
dick:green Post split off to a new topic so it doesn't get lost.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 167
Your connection is looking stable.
And the connection speeds seem fine:
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Are you connected wireless or wired?
 Chris Parr
 Plusnet Staff
