Re: Throttling at peak times?
TheChefuk
Hi
Been with plusnet for around 10 years, fibre for at least 7... no problems till a week ago now speeds as low as 2 Mbps from a constant 38-45 Mbps on wireless with 2 kids on ipads/xbox/phones etc .Seems a lot of people are having the same problems. Need to sort this out Plusnet...
11 REPLIES 11
MauriceC
Resting Legend
Fixes: 17
Hi @TheChefuk  Your problem probably needs to be investigated as a possible fault and should be in its own Topic.
Strat
Fixes: 565
Moderator's Note
Posts split to their own topic for clarity.
Fixes: 1,599
Welcome to the community forums @TheChefuk
I've got our suppliers to move your connection over to a different VLAN in the hope that will resolve the issues you're experiencing. It should complete within the next 48 hours and I've set a reminder for myself to check back then.
Mav
Fixes: 514
Moderator's note:
I locked @TheChefuk's other thread so as to keep support in one place.
Forum Moderator and Customer
Fixes: 1,599
Our suppliers have advised us that your circuit has been moved.
How are your speeds?
TheChefuk
Hi
A lot better! Up to 30/36 Mbps now ping sat at around 20/25. Will keep an eye on it. Thanks for the quick response and help. Cheers. 👍👍
Fixes: 1,599
I'm glad to hear that! Smiley
TheChefuk
Hi
Iam back to slow speeds again.... between 5-7 Mbps. Can anyone help? Been fine for the last 2 weeks now slowwwww again.
Fixes: 1,599
Our tests still aren't flagging any issues, but I'd like to take this back to our suppliers.
Can you run the BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end, and then report the fault to us at http://faults.plus.net
Let me know over here when you've done that and I'll look at it tomorrow.
TheChefuk
Hi Gandalf
Done the test and all seems fine!! Strange it was dipping so low last night, will keep my eye on it the next week or so. Thanks for your fast response and help
Cheers
Fixes: 1,599
That's good to hear Thumbs_Up
It's flagged to the relevant people and we're investigating though. Would be helpful to know if the issues return.
