Re-Synce - High SNR
- Re-Synce - High SNR
Re-Synce - High SNR
31-08-2019 2:02 PM
I've had 145 days uptime and i decided to reboot the router as the SNR was showing 6.7.
Having done that, my rate dropped from 51750 to 49708 with an SNR even higher at 7.3
How come this is happening?
I'm on the top tier speed package and i don't believe i'm aggressively interleaved with pings of between 9 and 11ms
Any recommendation to get my speed up and the target of 6.0 SNR?
thanks
Re: Re-Synce - High SNR
01-09-2019 10:52 AM
Thanks for getting in touch @Bp1000
It may have been that there was some noise on the line at the time which resulted in the router reconnecting at a higher rate.
Have you tried dialling 17070 from a landline to see if there's any noise on the line?
