Re: Problems with internet connection
- Re: Problems with internet connection
- « Previous
- 1
- 2
- Next »
30-01-2018 1:16 PM
Its likely to be username: admin - Password -password or 1234.
Worth a try whilst you wait, you can connect to it by typing http://192.168.1.1 in your browser.
30-01-2018 1:29 PM
Many thanks for that. You were right re the password. I've now had 'instructions' from my Plusnet Case Manager and STILL this new router won't connect. I expect the next thing they'll do is blame my computer! They are going to call me back some time this afternoon. I'm pretty sure they don't know what to do next!
30-01-2018 4:27 PM
Sorry to hear the broadband engineer couldn't fix the problem @seascapes99
Engineer notes advise the Hub One isn't compatible with the Huawei technology at the cabinet/exchange. And I'm also sorry to hear you're still unable to connect with a different type of router.
I'm raising an escalation with our suppliers now to see if we can get an experienced engineer assigned.
30-01-2018 4:35 PM
Digging into this I can see you had a very brief connection on Sunday:
This tells me that the problem wasn't with the compatibility of the Hub One. In addition, the router was *in sync* to the cabinet, but it just wasn't authenticating. If it was a compatibility issue it likely wouldn't sync at all.
I've raised the escalation now. We should have a response within a few hours and we'll go from there.
- « Previous
- 1
- 2
- Next »
