Re: Poor Service
- Re: Poor Service
Re: Poor Service
19-01-2021 7:09 PM
Re: Poor Service
21-01-2021 1:56 AM
A warm welcome to the forums.
Phone line faults can be reported on line from anywhere, if you have the account holder’s credentials. Log into the user portal and click the phone fault link below.
There are 4 typical outcomes from the fault test...
- A clear successful test reporting an identifiable fault typically this happens for external faults which can be attended to with out an end user appointment
- A failure of the test is reported, but a fault ticket is raised (see ticket link below)
- A failure of the test is reported, but a fault ticket is NOT raised
- The test reports no fault identified - some faults when tested from the exchange simply cannot be tested, for example if a shabby engineer cross connected the exchange line pair to a different premises, the line would quite like test no fault found
1&2 will normally lead to the fault being progressed without the need to contact support (note is your daughter.s mobile phone number on her account contact details?)
2&4 will need a voice call to support - note that you can use the 0800 numbers for free on a mobile phone and their batteries last far longer than those on (possibly old?) handsets. (One of mine last around 15-20 minutes).
If PlusNET testing reports no fault detected, you might need to suggest the possibility of a mis-connected circuit.
Re: Poor Service
21-01-2021 7:54 AM
Moderators Note
This topic has been split and moved to Fibre
Re: Poor Service
21-01-2021 1:01 PM
@Townman It seems the thread has been split and your post was obviously replying to some other thread so it won't make much sense to @Jamestillyer
