Re: New Upgrade - profile not updated
borisd0
Just been upgraded from PN ADSL to FTTC
Before upgrade:  down 3.7mbs. up 1.1mbs.
After upgrade:  down 3.7mBs up 6.99 mbs Ping 22
Estimated 26Mbs
I'm told that  I have to wait 10 days or so  to see the expected increased speed, is this correct?
To see no actual increase of speed when switching to fibre, is this normal?
Sounds like they need to update their speed profile but you'd be best off starting your own thread rather than piggy backing off this one Smiley
Fixes: 162
@kremmen
Thanks for that.
@borisd0
No, that's not correct. Give me 5 minutes, then log in to your router and press disconnect and then connect. Try a speedtest after that.
 Chris Parr
 Plusnet Staff
Fixes: 62
No it isn't and I just wish they would train the call handlers better
The problem is updating the Plusnet profile and that is what they should have done manually instead of spouting the up to 10 days guff which does not apply to fibre
I have split it off
Fixes: 162
Thanks Oldjim,
I've sorted the profile out and sent feedback on as this is an annoyance of mine.
 Chris Parr
 Plusnet Staff
