Re: Fibre slow down
Gorby
Re: Fibre slow down
I've noticed a slow down in the past few weeks also. Anything wrong with my area?
Moderator's note by Mike (Mav): Changed thread title slightly.
Fixes: 168
Re: Fibre slow down
Moderator's note:
Split to its own thread for better visibility.
Forum Moderator and Customer
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Fibre slow down
Testing your line isn't showing any issues at all:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 34.3 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
Your line is synced above the estimate range for your area:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 32 22.4 6.6 4.4 20 Available -- -- -- --
And it's very stable:
What speeds are you getting on a speedtest?
 Chris Parr
 Plusnet Staff
