Re: Fibre slow down
- Re: Fibre slow down
Re: Fibre slow down
on 08-06-2017 1:21 AM - last edited on 08-06-2017 1:29 PM by Mav
I've noticed a slow down in the past few weeks also. Anything wrong with my area?
Moderator's note by Mike (Mav): Changed thread title slightly.
Re: Fibre slow down
08-06-2017 1:30 PM
Moderator's note:
Split to its own thread for better visibility.
Forum Moderator and Customer
Re: Fibre slow down
08-06-2017 1:33 PM
Testing your line isn't showing any issues at all:
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 34.3 Mbps | ||||
Upstream Speed | 2.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N |
Your line is synced above the estimate range for your area:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 32 | 22.4 | 6.6 | 4.4 | 20 | Available | -- | -- | -- | -- |
And it's very stable:
