Re: Fibre broadband speed lower than guaranteed minimum
Pumpkin086
Could you test mine please? I get speeds anywhere as low as 0.5mbps, I'm not happy at all. I constantly change WiFi channels, and I've separated the SSID between the 2.4ghz and 5ghz and not found much improvement.
Thanks.
2 REPLIES 2
Fixes: 1,069
@Pumpkin086 Sorry to hear that. Our tests aren't showing any issues with the broadband signal going into your router. Can you try a wired connection to narrow down where the issue lies?
Strat
Fixes: 513
Moderator's note by Dick (Strat): Posts split to own topic for clarity.
Customer and Forum Moderator. Windows 10 Firefox 89.0 (64-bit)
