Re: Fibre broadband speed lower than guaranteed minimum
- Re: Fibre broadband speed lower than guaranteed mi...
07-07-2019 8:52 PM
Could you test mine please? I get speeds anywhere as low as 0.5mbps, I'm not happy at all. I constantly change WiFi channels, and I've separated the SSID between the 2.4ghz and 5ghz and not found much improvement.
Thanks.
Thanks.
Message 1 of 3
(375 Views)
2 REPLIES 2
08-07-2019 10:27 AM
@Pumpkin086 Sorry to hear that. Our tests aren't showing any issues with the broadband signal going into your router. Can you try a wired connection to narrow down where the issue lies?
Message 2 of 3
(348 Views)
08-07-2019 10:34 AM - edited 08-07-2019 10:35 AM
Moderator's note by Dick (Strat): Posts split to own topic for clarity.
Message 3 of 3
(339 Views)
