Re: Faulty BT Wholesale Broadband Performance Test
mort7890
So 2 weeks later sadly still the same.
1. Best Effort Test:
Download Speed : 52.4 Mbps
2. Upstream Test:
Upload Speed : 13.06 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Moderator's note by Mike (Mav): Changed thread title slightly to differentiate from previous thread.
14 REPLIES 14
mort7890
Re: BT Wholesale Broadband Performance Test Faulty
It works and even get faster speed than my profile
. Best Effort Test: -provides background information.
  Download Speed
  54.72 Mbps
0 Mbps 53.17 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 54.72 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-53.17 Mbps .
 Additional Information:
 IP Profile for your line is - 53.17 Mbps
  Upload Speed
  12.84 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 12.84Mbps
We were unable to identify any performance problem with your service at this time.
mort7890
Did not last long
Download Speed : 55.71 Mbps
2. Upstream Test:
Upload Speed : 12.85 Mbps
mort7890
Still the same a Month later
. Best Effort Test:
Download Speed : 57.15 Mbps
2. Upstream Test:
Upload Speed : 12.87 Mbps
mort7890
Sadly a Month has gone by still the same problem but even worse a reduction in speed from over 50 to
Download Speed : 31.17 Mbps
2. Upstream Test:
Upload Speed : 12.68 Mbps
goldenfibre
Fixes: 8
mort7890 you need to start new thread as this is my thread as it been fixed and resolved. So, plusnet staff will not pick it up here.
Fixes: 387
Moderator's note:
Thread split from https://community.plus.net/t5/Fibre-Broadband/BT-Wholesale-Broadband-Performance-Test-Faulty/td-p/14... for better visibility and title changed slightly.
Forum Moderator and Customer
Fixes: 845
I've worked the fault ticket on your account. You can view this here. We're seeing a high amount of usage flowing with your connection at the time of the test you've run previously.
We need you to complete the BTw speed test once more, making sure that you're using a wired connection and there are no other devices using your connection at the time of the test.
mort7890
Did a BT Speed test and then a speed test with Ookla.
BT D/L 19Mbps, Ookla 51Mbps screen shot attached hopefully.
However I did notice on Ookla that I am with BT Global Services, in the past when I have used Ookla it has shown Plusnet any ideas why please.
mort7890
Also have been looking at the event log in the Plusnet Hub1
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 46.21.151.94-​>51.6.164.150 on ppp3)
19:39:17, 10 Jul. IN: BLOCK [16] Remote administration (TCP [186.128.26.96]:39752-​>[51.6.164.150]:22 on ppp3)
19:38:55, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:64131-​>[104.82.70.180]:443 on ppp3)
19:38:54, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:64130-​>[104.82.70.180]:443 on ppp3)
19:36:42, 10 Jul. IN: BLOCK [16] Remote administration (TCP [212.129.23.96]:51778-​>[51.6.164.150]:22 on ppp3)
19:32:15, 10 Jul. BLOCKED 3 more packets (because of ICMP replay)
19:32:15, 10 Jul. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.164.150-​>157.240.1.32 on ppp3)
And it just goes on and on
19:15:45, 10 Jul. IN: BLOCK [16] Remote administration (TCP [103.89.91.218]:39818-​>[51.6.164.150]:22 on ppp3)
19:14:11, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:38304-​>[23.43.66.40]:443 on ppp3)
19:11:00, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:38091-​>[185.31.128.208]:443 on ppp3)
19:10:46, 10 Jul. BLOCKED 1 more packets (because of First packet is Invalid)
19:10:45, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:38030-​>[185.31.128.207]:443 on ppp3)
19:10:39, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:37989-​>[185.31.128.208]:443 on ppp3)
19:02:25, 10 Jul. IN: BLOCK [16] Remote administration (TCP [181.20.155.186]:41721-​>[51.6.164.150]:22 on ppp3)
19:00:56, 10 Jul. IN: BLOCK [16] Remote administration (TCP [197.231.192.249]:28149-​>[51.6.164.150]:22 on ppp3)
18:59:50, 10 Jul. IN: BLOCK [16] Remote administration (TCP [181.20.168.7]:24053-​>[51.6.164.150]:22 on ppp3)
18:59:18, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.68]:42866-​>[172.217.23.10]:443 on ppp3)
18:52:41, 10 Jul. IN: BLOCK [16] Remote administration (TCP [169.54.244.82]:10000-​>[51.6.164.150]:22 on ppp3)
18:52:24, 10 Jul. IN: BLOCK [16] Remote administration (TCP [61.155.198.222]:39062-​>[51.6.164.150]:22 on ppp3)
18:33:51, 10 Jul. IN: BLOCK [16] Remote administration (TCP [123.249.4.99]:20503-​>[51.6.164.150]:8080 on ppp3)
18:30:19, 10 Jul. IN: BLOCK [16] Remote administration (TCP [162.243.141.209]:54225-​>[51.6.164.150]:8080 on ppp3)
18:09:13, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:53148-​>[157.240.1.18]:443 on ppp3)
17:58:32, 10 Jul. IN: BLOCK [16] Remote administration (TCP [180.128.21.46]:54245-​>[51.6.164.150]:22 on ppp3)
17:53:57, 10 Jul. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 84.22.55.121-​>51.6.164.150 on ppp3)
17:51:40, 10 Jul. IN: BLOCK [16] Remote administration (TCP [185.35.62.20]:60485-​>[51.6.164.150]:80 on ppp3)
17:50:59, 10 Jul. IN: BLOCK [16] Remote administration (TCP [216.243.31.2]:49799-​>[51.6.164.150]:443 on ppp3)
17:26:34, 10 Jul. IN: BLOCK [16] Remote administration (TCP [125.111.137.173]:16967-​>[51.6.164.150]:22 on ppp3)
17:20:11, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.65]:51616-​>[193.0.160.207]:443 on ppp3)
17:10:07, 10 Jul. IN: BLOCK [16] Remote administration (TCP [185.35.62.60]:60613-​>[51.6.164.150]:443 on ppp3)
17:09:40, 10 Jul. BLOCKED 3 more packets (because of ICMP replay)
17:09:39, 10 Jul. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.164.150-​>216.58.198.106 on ppp3)
17:09:14, 10 Jul. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.164.150-​>216.58.201.14 on ppp3)
17:09:12, 10 Jul. BLOCKED 3 more packets (because of ICMP replay)
17:09:11, 10 Jul. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.6.164.150-​>216.58.201.14 on ppp3)
16:59:52, 10 Jul. IN: BLOCK [16] Remote administration (TCP [92.252.182.92]:21835-​>[51.6.164.150]:22 on ppp3)
16:54:28, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.65]:58197-​>[216.58.201.10]:443 on ppp3)
16:35:24, 10 Jul. IN: BLOCK [16] Remote administration (TCP [212.129.23.96]:40244-​>[51.6.164.150]:22 on ppp3)
16:31:49, 10 Jul. IN: BLOCK [16] Remote administration (TCP [212.129.37.229]:58441-​>[51.6.164.150]:22 on ppp3)
16:16:52, 10 Jul. IN: BLOCK [16] Remote administration (TCP [190.51.99.193]:52870-​>[51.6.164.150]:22 on ppp3)
16:04:13, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:57726-​>[172.217.23.10]:443 on ppp3)
16:04:09, 10 Jul. IN: BLOCK [16] Remote administration (TCP [221.194.44.212]:9090-​>[51.6.164.150]:22 on ppp3)
16:03:35, 10 Jul. IN: BLOCK [16] Remote administration (TCP [114.246.0.237]:32440-​>[51.6.164.150]:22 on ppp3)
15:58:22, 10 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:57726-​>[172.217.23.10]:443 on ppp3)
15:53:43, 10 Jul. IN: BLOCK [16] Remote administration (UDP [104.237.202.7]:60684-​>[51.6.164.150]:161 on ppp3)
Will all this continuous activity affect the speed?Huh
Fixes: 245
The router log doesn't seem to flag up anything for concern as far as I can see.
51Mbps on a speed test seems in line with the estimates for your line, which are 49-67.1Mbps.
However I appreciate they're recording low on the BT Speed tester. Are you actually experiencing slow speeds, or is this just via the BT Speed tester?
 Harry Beesley
 Plusnet Infrastructure Operations Professional
mort7890
But it does seem to be constantly doing this
20:32:16, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:47423-​>[172.217.23.42]:443 on ppp3)
20:26:31, 12 Jul. IN: BLOCK [16] Remote administration (TCP [37.203.205.172]:36870-​>[51.6.164.150]:22 on ppp3)
20:23:21, 12 Jul. IN: BLOCK [16] Remote administration (TCP [58.218.205.102]:9090-​>[51.6.164.150]:22 on ppp3)
20:23:10, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:49595-​>[193.0.160.207]:443 on ppp3)
20:16:32, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:48761-​>[185.31.128.207]:443 on ppp3)
20:16:26, 12 Jul. IN: BLOCK [16] Remote administration (TCP [60.191.38.78]:13247-​>[51.6.164.150]:22 on ppp3)
20:07:35, 12 Jul. IN: BLOCK [16] Remote administration (TCP [139.162.111.147]:60052-​>[51.6.164.150]:80 on ppp3)
20:03:30, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.67]:47228-​>[193.0.160.206]:443 on ppp3)
19:57:50, 12 Jul. IN: BLOCK [16] Remote administration (TCP [188.138.75.71]:12900-​>[51.6.164.150]:80 on ppp3)
19:49:41, 12 Jul. (453753.850000) CWMP: session completed successfully
19:49:41, 12 Jul. (453753.680000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
19:49:39, 12 Jul. (453751.690000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
19:49:39, 12 Jul. (453751.690000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
19:49:39, 12 Jul. (453751.410000) CWMP: Initializing transaction for event code 2 PERIODIC
19:47:44, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:53709-​>[34.228.93.99]:443 on ppp3)
19:39:51, 12 Jul. IN: BLOCK [16] Remote administration (TCP [83.81.38.66]:44790-​>[51.6.164.150]:80 on ppp3)
19:37:00, 12 Jul. IN: BLOCK [16] Remote administration (UDP [158.85.81.119]:25533-​>[51.6.164.150]:161 on ppp3)
19:34:56, 12 Jul. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:43425-​>[31.13.90.2]:443 on ppp3)
Speeds seem fine it just shows a slow speed via the BT Speed Tester.
But still not got an answer why does Ookla show I am with BT Global Services, everywhere I ask it seems to be ignored
Chris
Legend
Fixes: 168
Your router log will shows lots of things, especially when you log in to the router as it records each event that passes through it including logons etc. It's absolutely nothing to worry about.
Ookla speedtests may show that you're with Global Services as the IP address you are connected on will have been one of theirs at some point and the record simply hasn't updated. Again, nothing to worry about.
mort7890
Thanks Chris, however I remember checking, albeit some months back, my speed through Ookla and I was then registered with Plusnet. Presume then my IP address has been changed but as you say nothing on that point to worry about as Plusnet is part of BT.
On the other hand, in the log there is:-
Which does concern me having researched CWMP on the internet, why would this happen when I am not with BT.
Chris
Legend
Fixes: 168
All that's doing is connecting to a TR069 (auto-setup) server that we use to ensure your connection details are correct.
