Re: Fault on my line
carlsthebest
if like mine ive been trying for 2 years now to get pluss net to fix mine i had a stable 78.1Mb connection with talk talk.
when i switched to plussnet it was dropping and now 2 years later after purchasing static ip to eradicate the 195 ip addresses routing us to the usa then belgum before we get to what we want. also £300 on new router.
yet im stuck now only recieving 43Mb so you tell me i wait 45mis every time calling customer service (if you can call it that) prommised so many callbacks that dont happen and now yesterday they tell me there is an impairment in my line of which i told them last year as dsl reports found for me. now waiting again for a fix but they never reimburse we have to look into this first is all i get and this is 2 years worth of superfast fiber extra
Moderator's note by Mike (Mav): Title changed after being split to its own thread.
5 REPLIES 5
carlsthebest
what is the point in contacting people who will do nothing but fob you off with rubbish i mean for a start my ip profile is always dropping
Chris
Legend
Fixes: 169
Hi there @carlsthebest
Looking at your account you reported this issue again yesterday, we tested the line and detected an 'Impairment in copper joint detected most likely in local network.' and reported this to Openreach for investigation. If there's a fault on the phone line, that's likely to be causing the problems you're seeing. Once we hear back we'll update you with what's happening.
carlsthebest
and again they will come back its ok within 80% as my ip profile is only 53 at mo
carlsthebest
and why has it taken so many calls from me to get this far again not one of your support team have said the same thing they all have diferent answers its probably router as ours are not much cop.
then go getting all new cables
new adsl filter to test outlet socket all this at my cost not to mention allways paid for fiber extra but never recieved
Mav
Fixes: 515
Split to its own thread and title changed
Forum Moderator and Customer
