Re: Broadband keeps dropping
- Re: Broadband keeps dropping
09-11-2016 10:29 PM
10-11-2016 11:43 AM - edited 10-11-2016 11:45 AM
Split to its own thread
Forum Moderator and Customer
10-11-2016 11:53 AM
Hi Chris,
Testing your line indicates a potential issue with the equipment connected to the phone line which is likely to be impacting your broadband too. A loop has been found, which is basically a short circuit on the line.
Usually this is down to a faulty piece of equipment within your own property. The next step would be to test the connection directly into the test socket to see if your broadband is still disconnecting. From there, we'd also be able to retest and see if the results are the same on our side.
Let us know if there's anything further we can do.
Matty
10-11-2016 1:50 PM
I too have been having issues. So far today it has dropped out around 5 or 6 times since 1pm
