Re: Another seriously hacked off fibre user
bikerchic44
Why is the download speed so slow?
I'm supposed to have superfast fibre, my xbox is wired to the router but downloading a game takes hours because
it is only downloading at 5 to 10 mps. Where is the so call 80mps download speed?
I'm also a seriously hacked off fibre user!!!
Browni
Seasoned Champion
Fixes: 37
Re: One seriously hacked off fibre user
bikerchic44 wrote:
 ... it is only downloading at 5 to 10 mps. Where is the so call 80mps download speed?
Are you sure you are not getting bits & bytes mixed up?
Downloads are normally measured in MegaBytes per second whereas connection speeds are normally measured in Megabits per second.
10MBps = 80Mbps
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
bikerchic44
it says Mb/s
geek26
Try the BTW Speedtest here and then do the further diagnostics test reporting the results back here
James
Fixes: 142
Moderator's note by Mike (Mav)
Message and its replies split to new thread and title changed
Forum Moderator and Customer
Fixes: 171
Unfortunately you don't appear to have contacted us via your account to advise of any problems for us to investigate.
Testing your connection isn't indicating any problems with the speed and shows you're in sync extremely close to the full 80/20.
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 119.4
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Can you try going through our troubleshooting guide if you haven't already.
If you continue to experience slow speeds after this, I'd recommend raising a fault so we can investigate further.
 Harry Beesley
