Random Results Hub One vs HG612/2704n
Fixes: 4
Seem to be getting random results with this Hub One modem/router.
Can somebody please have a mooch to see if Retransmission is enabled or not.
Previous setup was HG612 with 2704n.
Wifi:   Dissabled
dhcp: Dissabled
ipv6:  Dissabled
3. Software version:     4.7.5.1.83.8.217.1.1
4. Board version:          Plusnet Hub One
5. DSL uptime:             16 days, 17:59:30
6. Data rate:                 2001 / 39993
7. Maximum data rate: 5922 / 43243
8. Noise margin:           15.9 / 8.1
9. Line attenuation:      26.1 / 25.9
10. Signal attenuation: 26.3 / 23.5
Download speedachieved during the test was - 36.44 Mbps
For your connection, the acceptable range of speeds is 27.1 Mbps-38.71 Mbps .
Additional Information:
IP Profile for your line is - 38.71 Mbps
Upload speed achieved during the test was - 1.82Mbps
Upstream Rate IP profile on your line is - 2 Mbps
146589901046179511662
I changed over from BT on the 25th May with quite solid results of around 37mbps
but now getting spurious results around 34mbps as follows, same sort of thing with TBB above as well so I'm pretty sure the random results are not being caused my side.
Date Downstream (Mbps)  Min	Max	Samples
22nd May, 2016	37.10	36.97	37.17	9
23rd May, 2016	36.71	32.13	37.18	12
24th May, 2016	37.13	37.05	37.18	9
25th May, 2016	37.12	37.12	37.12	1
26th May, 2016	34.56	31.80	36.14	4
27th May, 2016	33.99	30.51	36.15	6
28th May, 2016	34.94	34.31	36.15	3
31st May, 2016	34.62	33.61	36.15	7
1st Jun, 2016	35.21	34.26	36.15	4
2nd Jun, 2016	34.21	32.36	36.14	5
3rd Jun, 2016	33.81	29.32	36.14	12
4th Jun, 2016	31.61	26.17	34.33	3
8th Jun, 2016	34.33	32.45	36.19	4
9th Jun, 2016	33.99	28.89	36.16	12
10th Jun, 2016	35.25	34.35	36.15	2
11th Jun, 2016	34.14	33.72	34.36	3
12th Jun, 2016	35.42	34.34	36.43	7
13th Jun, 2016	33.15	29.01	34.34	7
14th Jun, 2016	34.86	34.34	35.88	3
 Although I am getting Radom results... on the whole plusnet seems all little more together regarding everything working as expected these days (New Network Changes maybe)... may it continue this well.
SpendLessTime
Aspiring Hero
Fixes: 67
Re: Random Results Hub One vs HG612/2704n
Possible congestion at the exchange or Plusnet Gateway when the TTB graph bands are apart.
Your Plusnet gateway is given at http://users.plus.net/@gateway_custom?debug-ip=yes
Fixes: 4
Array
    [1] =>  7  core3-hu0-3-0-0.faraday.ukcore.bt.net (213.121.193.160)  2.931 ms
    [2] =>  8  acc2-10GigE-0-2-0-3.l-far.21cn-ipp.bt.net (109.159.249.158)  3.828 ms
    [3] =>  9  195.99.126.99 (195.99.126.99)  3.730 ms
    [4] => 10  ae1.ptw-cr02.plus.net (195.166.129.2)  3.546 ms
    [5] => 11  link12-central10.pcl-ag02.plus.net (84.93.249.55)  3.704 ms
You are currently connected to gateway pcl-ag02.
Fixes: 4
I can see your point with the congestion, but moving and re-testing still gives me an average of around 34/35mbps so thats not whats causing the drop of around 2mbps on average, I'm still suspecting G.INP off though
SpendLessTime
Aspiring Hero
Fixes: 67
Could be G.INP, I just know from experience that (for me) that style of TTB graph means gateways issues. But YMMV Smiley
Fixes: 4
Indeed, lets see if one of the Plusnet guys can rule that one out!
Fixes: 20
The effect of the Plusnet profile is probably the cause of the reduction in the maximum speeds recorded.
Fixes: 4
It's a guessing game without more information Sad
I might chuck the unlocked HG612 in front at some point just to see whats what.
