RT-AC88U do I need BT Modem?
- Re: RT-AC88U do I need BT Modem?
29-09-2016 12:32 PM
I have just purchased an Asus RT-AC88U Dual Band Gagabit Router as we are totally fed up with the number of lags and drop outs we are experiencing. I thought I had done my research and purchased this router to replace the plusnet router and the BT modem but in the set up guide it is showing connecting to a modem! Can anyone tell me have a I purchased an expensive pig in a poke?
29-09-2016 12:37 PM
Yes, it needs a modem.
29-09-2016 12:40 PM
You should have bought an ASUS where the model begins DSL-. Any chance of you doing an exchange?
If you have a BT modem you can connect the one you've bought to that.
29-09-2016 12:40 PM
Thanks for that. So the guy I spoke to at Ebuyer misled me. Is it a detriment needing a separate modem?? I was aiming to lose the modem and just have the one box.
29-09-2016 12:42 PM
Thanks, as you can guess all of this is alien to me! Will it work fine with the BT Modem? Or should I swap it? It was not cheap!!
29-09-2016 1:13 PM
It will be fine with the BT modem
29-09-2016 3:01 PM
Thank you!! Now have it set up and working, it seems much faster should have done this ages ago I was just too scared 🙂
