Question about using my new router
- Question about using my new router
22-09-2015 7:57 PM
I have recently signed up with Plusnet's fibre service which is being installed on the 2nd October.
I currently have ADSL broadband with another provider, and in preparation for the new service I have bought a Billion AC8800AXL router. I was thinking about setting up my router with my existing providers service until the Plusnet service is up and running.
I'm not very knowledgeable on this sort of thing and wanted to ask if would cause any issues when the Plusnet service starts.
Thanks,
Tom
Thanks,
Tom
Message 1 of 6
(1,001 Views)
5 REPLIES 5
Re: Question about using my new router
22-09-2015 10:08 PM
You should be Ok, if any issues just reset the router to factory settings and start again
Message 2 of 6
(702 Views)
23-09-2015 4:54 PM
As above. No issues should be encountered.
Matty
Matty
Message 3 of 6
(702 Views)
23-09-2015 8:16 PM
Thanks, I will connect it up tomorrow and see how things work out.
Tom
Tom
Message 4 of 6
(702 Views)
24-09-2015 11:41 AM
Let us know if you have any issues.
Message 5 of 6
(702 Views)
24-09-2015 11:54 AM
I set everything up this morning and it's working fine. The router is giving a maximum speed of around 500-600 Mbps, whereas my previous Netgear router was never more than about 48Mbps.
Tom
Tom
Message 6 of 6
(702 Views)
