Question about broadband speed
- Question about broadband speed
11-09-2019 11:21 PM
Hi
So moved from BT to Plusnet and signed up to Unlimited Fibre Extra and have been connected for 2 weeks, and my line stats are the following from the PlusNet One modem
16.59 Mbps
However when I do a speed test I'm getting 35-36 Mbps Download speed and 12-13 Mbps upload speed, I've received an email saying
When you signed up for Plusnet Broadband, we gave you an estimated line speed range. Now that your Unlimited Fibre Extra broadband has been up and running for 14 days, we wanted to let you know your line speed as it stands today, as a comparison.
Estimated peak time speeds:
Download: 43 - 62Mb
Upload: 10 - 16Mb
These are the speeds your line is capable of at peak times.
Current line speed: 78Mb
This is a measure of the actual line speed you are now receiving based on the product you have taken.
Minimum Guaranteed Speed: 38.1Mb
This is the minimum speed you should expect to achieve on your line.
Now when I was on BT my line stats the HH6 where Downsteam: 60Mbps, Upsteam: 20Mbps upload and when running a speed test give I was getting 54-56 download speed and 17-18 upload speed, and I know that I wasn't getting the full 60 download and full 20 upload speed when doing a speed test but losing 13mb download is puzzling if my Downsteam is 47Mbps.
I've tried switching the modem off for a while and switching it back on after 30 second but am still getting 35-36 Mbps Download speed, plus I would like to also know where the hell Plusnet have got my current line speed at 78Mbps from when its 47Mbps
Re: Question about broadband speed
12-09-2019 9:16 AM
Check advanced on the BT Wholesale Speed Test to see what your profile is set at as this can affect the results
12-09-2019 9:25 AM - edited 12-09-2019 9:27 AM
@TeessideChris78 Welcome to the forum.
First of all the 78Mbps refers to the contract you are on, that is up to 78/18, not really 80/20. Not the speed that they are measuring.
Next the router is reporting the synchronous rate between your router and the fibre cabinet. Because of handshaking requirements and error correction this is always higher than the data rate.
When you change suppliers Openreach reset the DLM which can cause a temporary reduction in speed. This will hopefully automatically recover.
If you still have your Smarthub 6 then like many of us use that rather than your Plusnet Hub One, which is a tweeked old Home Hub 5A. The Smarthub has better WiFi and the firmware is less buggy. Setting instructions are here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
19-09-2019 11:01 PM
Well switched out the PlusNet modem for the Smarthub 6 and am getting exactly the same sync speeds that I did with BT before my contract ended with them, but 2 months prior again was getting sync speeds of 60/20 until something happened on the 21st June and my sync speeds got decreased
20-09-2019 11:27 AM
I've just reset the line profile for your account - could you please carry out a speed test via a wired device and let me know the results?
Dave
20-09-2019 11:50 AM
Again just checked my profile and it shows at download 47.37Mbps, but according to my account my current Line Speed (Download): 50.6Mbps.
Testing through BT Wholesale Speed Test I am getting 44.8Mbps
I am sure a while ago my profile was up towards the 60Mbps marker
on
20-09-2019
1:19 PM
- last edited on
20-09-2019
2:03 PM
by
Hi @mort7890
We have two different accounts logged against your community profile - are you speaking about the church this time or not?
Thanks,
MoR
Moderators Note: Corrected typo
20-09-2019 2:59 PM
Not the Church
20-09-2019 3:37 PM
Hi @mort7890
Your profile is currently at 0.128M-49M Downstream.
I can't see any reason for this to have happened, so I can only offer my apologies. I've raised a fault to get it amended to 80/20 now.
Thanks,
MoR
20-09-2019 4:44 PM
Many thanks for picking this up, just as a point to note, I made mention on the 10th June under BT Wholesale Speed Test
10-06-2019 5:23 PM
Still going in bursts of 20% also urealistic speeds as detailed so still broken. However what concerns me is that the IP Profile has dropped from 57.5Mbps to 45.4Mbps is this BT or Plusnet
and this was not picked up.
Will see if my profile has changed and let you know.
20-09-2019 5:09 PM
This was the BT profile.
I can take up to 48hrs for the profile to be fully amended - just fyi
Thanks,
MoR
20-09-2019 6:38 PM
20-09-2019 6:41 PM
Hi @mort7890
I assumed by the above you were asking if it was the OR or PN profile which was banded?
I must have been wrong - let me know what you meant and I'll revise my answer
Thanks,
MoR
23-09-2019 9:55 AM
The hub connection shows 48.94Mbps upstream and 13.22Mbps downstream
On the BT wholesale speedtest My line IP Profile is as attached
Trust this gives you the information.
23-09-2019 12:12 PM
Hi there @mort7890
Sorry for the delay. I can see @MasterOfReality sent a request to our suppliers for your profile to be amended. As this was sent after 3pm on Friday it missed the deadline and will be sent through for action today. Its normally around 1-2pm and you should notice the change within 24-48 hours from this afternoon.
Sorry for any inconvenience.
