Question #132616954..............Update required
Fixes: 4
The above question resulted in a fault being raised. According to the thread there should have been an update 3 days ago but nothing has come through. Could one of the EXCELLENT FORUM STAFF members please send a hastener??Angel
Fixes: 165
Re: Question #132616954..............Update required
I've just tested the line and it's in sync within the estimate range.
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
 Chris Parr
 Plusnet Staff
Fixes: 4
Thanks Chris, will do.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules
Fixes: 4
I've done the test Chris. The download looks OK but I don't understand why my upload has halved. This occurred 2-3 weeks ago & from reading the forum, I don't seem to be alone with this problem.
Fixes: 165
Your line is provisioned correctly, so that's not the cause. The sync on the upload has dropped to below the estimate, the next step would be to book an engineer to investigate so I'll update the ticket with this information.
 Chris Parr
 Plusnet Staff
Fixes: 4
Thanks Chris, I've replied to your update & provided my dates/ times of availability. Your assistance is much appreciated.
Fixes: 165
I'm just booking that now, I'll confirm the date on the ticket.
 Chris Parr
 Plusnet Staff
