Question #127948569
stoswald
Question #127948569
Raised on Sunday Evening around 9pm - almost 48hrs later and no update from Support.
Angry
Terranova667
Re: Question #127948569
Sadly it's 72 hrs for support to reply to tickets raised and that's if they do, sometimes it requires given them a nudge
Fixes: 162
Looking at the fault ticket, it's been reported as an intermittent connection. We're not seeing a large number of disconnects over the last few days. There were a few on Saturday/Sunday but it's been generally stable since then. Are you still having the same issues?
 Chris Parr
 Plusnet Staff
stoswald
The Sam Knows graphs have settled down, however my IP Profile is a bit on the low side.  BTO has set my
IP Profile at 70.99, I am seeing a higher MDR, so should be able to get an IP Profile of 76mbs as I was with BT Infinity 2
6. Data rate: 19999 / 73338
7. Maximum data rate: 28150 / 73408
8. Noise margin: 14.9 / 6.4
9. Line attenuation: 17.2 / 15.1
10. Signal attenuation: 17.3 / 15.1
Can you please  therefore adjust my IP Profile, thanks
Fixes: 162
Your IP profile is correct, the *sync* speed dictates the profile. As you're synced at 73338, a profile of 70.9Mb/s is correct as the profile is 96.7% of the sync speed.
 Chris Parr
 Plusnet Staff
stoswald
Will it naturally increase or can something be done to give me what I was getting with BT Infinity 2 ?
Fixes: 162
it may increase, however it may also decrease. I'm afraid that as it's well inside the estimate range there is little we can do.
 Chris Parr
 Plusnet Staff
stoswald
Thanks. Lets hope it increases.  I've looked at my Sam knows graph for this time last year and I am getting the same speed as then and after 3 weeks the IP reset upwards and I enjoyed 2 occasions where I was maxed out - 74.29 on 24/11 & 74.05 on 28/5 - I can hope Wink
