Put in my own router with VDSL2 (Juniper SRX110H2-VA)
- Put in my own router with VDSL2 (Juniper SRX110H2-...
04-11-2019 11:25 PM - edited 04-11-2019 11:26 PM
After a bit of messing about and learning how junos works, I managed to get a connection, and it appears to be pretty decent. However I wondered if someone in the know can take a peek at the stats and make sure they look sane. Not sure what my MTU and MSS should be (for example), and there may be other less than optimum settings. Will the swap cause my line to retrain? Thanks.
show interfaces pt-1/0/0 extensive
Physical interface: pt-1/0/0, Enabled, Physical link is Up
Interface index: 149, SNMP ifIndex: 507, Generation: 155
Type: PTM, Link-level type: Ethernet, MTU: 1518, VDSL mode, Speed: VDSL2
Device flags : Present Running
CoS queues : 8 supported, 8 maximum usable queues
Hold-times : Up 0 ms, Down 0 ms
Current address: secret
Last flapped : 2019-11-04 22:41:27 GMT (00:25:29 ago)
Statistics last cleared: Never
Traffic statistics:
Input bytes : 92169 472 bps
Output bytes : 75427 0 bps
Input packets: 1536 0 pps
Output packets: 2075 0 pps
Input errors:
Errors: 0, Drops: 0, Policed discards: 0, L3 incompletes: 0,
L2 channel errors: 2, L2 mismatch timeouts: 0, Resource errors: 0
Output errors:
Carrier transitions: 7, Errors: 0, Drops: 0, Aged packets: 0, MTU errors: 0,
Resource errors: 0
Egress queues: 8 supported, 4 in use
Queue counters: Queued packets Transmitted packets Dropped packets
0 best-effort 2462367 2461924 443
1 expedited-fo 0 0 0
2 assured-forw 0 0 0
3 network-cont 2294 2294 0
Queue number: Mapped forwarding classes
0 best-effort
1 expedited-forwarding
2 assured-forwarding
3 network-control
VDSL alarms : None
VDSL defects : None
VDSL media: Seconds Count State
LOF 79 0 OK
LOS 79 0 OK
LOM 0 0 OK
LOP 0 0 OK
LOCDI 0 0 OK
LOCDNI 79 0 OK
VDSL status:
Modem status : Showtime (Profile-17a)
VDSL profile : Auto Annex B
Last fail code: None
Subfunction : 0x00
Seconds in showtime : 1532
VDSL Chipset Information: VTU-R VTU-C
Vendor Country : 0xb5 0xb5
Vendor ID : BDCM BDCM
Vendor Specific: 0x9385 0xa48c
VDSL Statistics: VTU-R VTU-C
Attenuation (dB) : 0.0 0.0
Capacity used (%) : 0 0
Noise margin (dB) : 8.5 16.0
Output power (dBm) : 12.0 0.5
Interleave Fast Interleave Fast
Bit rate (kbps) : 79999 0 20000 0
CRC : 0 0 0 0
FEC : 0 0 0 0
HEC : 0 0 0 0
Packet Forwarding Engine configuration:
Destination slot: 0 (0x00)
CoS information:
Direction : Output
CoS transmit queue Bandwidth Buffer Priority Limit
% bps % usec
0 best-effort 95 19000000 95 0 low none
3 network-control 5 1000000 5 0 low none
Logical interface pt-1/0/0.0 (Index 80) (SNMP ifIndex 533) (Generation 170)
Flags: SNMP-Traps 0x0 VLAN-Tag [ 0x8100.101 ]
Encapsulation: PPP-over-Ethernet
Traffic statistics:
Input bytes : 129
Output bytes : 337
Input packets: 2
Output packets: 4
Local statistics:
Input bytes : 129
Output bytes : 337
Input packets: 2
Output packets: 4
Transit statistics:
Input bytes : 0 0 bps
Output bytes : 0 0 bps
Input packets: 0 0 pps
Output packets: 0 0 pps
Security: Zone: Null
Flow Statistics :
Flow Input statistics :
Self packets : 0
ICMP packets : 0
VPN packets : 0
Multicast packets : 0
Bytes permitted by policy : 0
Connections established : 0
Flow Output statistics:
Flow error statistics (Packets dropped due to):
Address spoofing: 0
Authentication failed: 0
Incoming NAT errors: 0
Invalid zone received packet: 0
Multiple user authentications: 0
Multiple incoming NAT: 0
No parent for a gate: 0
No one interested in self packets: 0
No minor session: 0
No more sessions: 0
No NAT gate: 0
No route present: 0
No SA for incoming SPI: 0
No tunnel found: 0
No session for a gate: 0
No zone or NULL zone binding 0
Policy denied: 0
Security association not active: 0
TCP sequence number out of window: 0
Syn-attack protection: 0
User authentication errors: 0
Logical interface pt-1/0/0.32767 (Index 83) (SNMP ifIndex 540)
(Generation 172)
Flags: SNMP-Traps VLAN-Tag [ 0x0000.0 ] Encapsulation: ENET2
Traffic statistics:
Input bytes : 91800
Output bytes : 0
Input packets: 1530
Output packets: 0
Local statistics:
Input bytes : 91800
Output bytes : 0
Input packets: 1530
Output packets: 0
Transit statistics:
Flow Statistics :
Self packets : 0
ICMP packets : 0
VPN packets : 0
Address spoofing: 0
No minor session: 0
No more sessions: 0
No NAT gate: 0
No route present: 0
No tunnel found: 0
Policy denied: 0
Re: Put in my own router with VDSL2 (Juniper SRX110H2-VA)
05-11-2019 1:46 PM
The MTU may be a bit high at 1518. I've got it in my head that to avoid fragmentation it shouldn't be set higher than 1492.
05-11-2019 5:24 PM
Hi, I get really confused by MTU and MSS, as it seems to vary by broadband product. Can someone from Plusnet confirm the correct MTU and MSS settings for Plusnet VDSL2 Fibre to the cabinet. Thanks.
05-11-2019 5:35 PM
Hi @Mark_g1, as @Baldrick1 advises we usually say 1492 would be the best MTU setting. I'm afraid we don't advise on what MSS to use however I've found an older thread which may help here:
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/RWIN-MTU-MSS-etc/td-p/970078
