Progressive speed drop
robbiecollie
over the past couple of months my speed has dropped from an average 71 down to 55 at any time of the day on a wired connection any suggestions
5 REPLIES 5
Fixes: 104
Re: Progressive speed drop
Hi robbiecollie and welcome to the Community!
Checks against your account details and a diagnostic test aren't showing any obvious problems so I'd advise doing the following if/when this becomes apparent again:
Following that, do feel free to update this thread again and we'll be able to take a further look at this for you.
 Adam Walker
robbiecollie
Hi Adam have just checked by BT profile and that has dropped by 10Mmps
robbiecollie
BTW Performance test
Hi for the past eighteen months my speed profile has been constant at 71 Mbps down and 16 Mbps up now it has dropped by 10 Mbps with resulting loss of download speed have tried to raise a fault ticket on line but no luck any ideas anyone
Fixes: 667
mod:note
two topics merged together to keep help / information in one place.
Fixes: 104
Can you give the suggestions a try I mentioned in reply to your original post please?
    Connect your PC directly to the Openreach modem, this will help rule the router out of the equation which would be wise. We have a guide for that here, it specifically gives instructions for Windows 7 and Vista but you shouldn't find things too different if using an updated version of Windows 8 for example: http://community.plus.net...ialler-in-vistawindows-7/ ;
    Run a speed test at: http://speedtest.btwholesale.com/ ;
    Raise a fault online here: http://faults.plus.net ;
Can you let us know what happens when you try to raise a fault, I've checked your account and can't see anything obvious that might cause a problem with that.
let us know how you get on and do shout up if there's anything you're unsure about.
 Adam Walker
